TK,
THanks for the quick reply.
I'm currently driving the boards with TTL as they are not opto-isolated, and they accept login inputs from 3 - 5.5 V.
Currently, if I do a 'Step', I will usually get the motor to do a step 'forwards' and then a step 'backwards'. If I do a 'Move' command though I usually don't get anything. I also don't get anything in KMotionCNC when I use the arrow keys to move things. I don't need to run the motors that fast, this is a foam cutting CNC machine and you can't drag a hot wire through foam all that fast. I would like to move about 2kHz though which may be too fast.
I will try inverting the pulse and see what happens. THanks you for the suggestion.
On another note, how do you set the Step frequency? I can't seem to find this anywhere in the setup.
THanks,
> I can't think of a workaround for that unless you only need to step really slow
> (<1KHz) then you could do it with software. You might try that as a test to
> verify that really is the issue.
> You might also try inverting the pulse polarity (add 0x80 to the word you write
> to the FPGA pulse time). Sometimes drivers can handle short low going pulses
> better than high going pulses.
> Are the drives not working at all? Or are they missing some steps? Are you
> driving them as open collector or TTL?
> From: loki1725 <loki1725@...>
> Sent: Sat, February 19, 2011 6:19:56 PM
> Subject: [DynoMotion] 5us Pulse using KFLOP
> Hello,
> I'm trying to use the KFLOP to drive an old foam cutting CNC machine I have and
> my Stepper Motor Driver board says it wants a 5us pulse input for 'Step'. I have
> the KFLOP set up to give a 4us (using a divisor of 62 in the FPGA) but my motors
> aren't working. Is it possible to use something other than the FPGA step driver
> to output a 5us pulse?
> Thank you,
